Krzy Wski aka Hałas Efektors
- resynthesis
Re: Krzy Wski aka Hałas Efektors
Very nice indeed.
BTW How are those PCBs?
- jetofuj
- resynthesis
Ace, ta
- kosta
That bass clip sounds goooooooood. Dang!
- jetofuj
I had predrilled enclosure for an old project and booster board ready, so I was forced to build 3 knob version with led and dc jack
Except range control and boost volume, you have bias - full clockwise is "standard" voltage, that you can lower. The difference is sublte, but changes the feel indeed - from open to more compressed/fatter signal.
No corners cut, including NOS black glass OC43.
$olded
$olded
- black_booster_top.jpg (131.65 KiB) Viewed 4787 times
- black_booster_guts.jpg (198.95 KiB) Viewed 4787 times
- jetofuj
This turned really great, imo. Bass lines were recorded with Rick into Hiwatt with black drive or/and black booster in between
https://bitchcraftband.bandcamp.com/
- Lee
Looks awesome wish I had the monies could use one
Your builds are always top notch wish you built more like you use too
- jetofuj
Thanks Lee It's simply too cheap to be true
Of course you can always send it back, if you don't like it (minus shipping fees).
- jetofuj
I guess that everybody is fed up with booster, but here it goes
Black Yak - rangie with range, bias and boost controls + 2 switchable transistors: OC72 for cleaner tones and high gain OC43. My aim was to create really flexible booster that you can use with different guitars/pedals/amps. And of course, I really dig 2 board construction
Out of stock
Out of stock
- black_yak_1_top_1.jpg (354.05 KiB) Viewed 4277 times
- black_yak_1_guts_2.jpg (495.65 KiB) Viewed 4277 times
