Earth Sound Research - Graphic Fuzz (Data Dump)
FOXFIRE
Re: Earth Sound Research - Graphic Fuzz (Data Dump)
Post by FOXFIRE »
ok maybe i don't quite have the wiring right...
jerms
Post by jerms »
i don't understand it but i think this is it!
jerms
Post by jerms »
yeah this thing is ungodly loud!! :freakout: i was using it on a fender champ earlier (so as to not wake the napping baby). and when i hit the switch to turn it off i couldn't hear the signal at all, since i had to turn the amp to under 1 to control the fuzz!! ef'in LOUD.
hey sickle or captain, on yours does the signal disappear when the filter is turned fully up?
SonicVI
Post by SonicVI »
I think the filter pot is just controlling the gain of the opamp, so it would make sense that when it's turned all the way one way that you would be turning the gain down to 0 (from 100 at the opposite extreme). Usually when this is done there will be a resistor in series with the pot to set a minimum gain that's above zero, but that's not done here.
jerms
Post by jerms »
where's the analogguru to explain all this!!
SonicVI
Post by SonicVI »
Yeah, on second though, I don't think an opamp can have zero gain, we need a smart builder.
jerms
Post by jerms »
i don't get how you get a moving filter with a pot and a .1 cap. i guess that's not all there is to it though. i wonder if the output is feeding back to the input through the filter pot?
jerms
Post by jerms »
the clone, sounds just like the original!! :marx: super easy build!! :tu: the original uses linear taper pots, audio pots let you have a little more control over the gain (ie.. doesn't get so loud so fast).
FOXFIRE
Post by FOXFIRE »
I drew up a schematic, would you mind having a look at it?
http://www.aronnelson.com/gallery/main. ... C.png.html
jerms
Post by jerms »
the only thing different i see is the ground on the output jack is connected to the bottom of the level pot thus connecting to the 220 ohm, pin 3 on the IC, the .1 cap on the input etc... the input jack grounds through the chassis. and there's an isolated switch on the input jack, that connects the - of the battery to pin 4 on the IC and the .1/10K. kinda strange... :hmm: the - of the battery doesn't hook to the chassis & circuit ground...
Users browsing this forum: Ahrefs [Bot] and 1 guest
