2 trannie/9V version of Sekova wedge fuzz (Data Dump)
Pics, info, thoughts on old and/or hairy gear.
simonm
Post by simonm » Thu Nov 06, 2008 9:09 pm
The first Sekova chrome wedge is a faithful clone of the Maestro Fuzztone FZ1-A operating on a single AA battery - 1.5V. There is an eyelet board version and a pcb version of this one.
The next version has the same enclosure but an entirely different circuit (FA II) - seen here.
photos show - whole of interior (modified with an extra hole for input jack), close up of component side of pcb (numbered), and bottom of pcb (it was covered in tape, but adhesive was mostly dried up and it came away easily). Transistors are Matsushita 2SB173 - PNP Germanium. Diodes probably germanium. The white component is a polarised tantalum capacitor. This version seems to have been also been branded Apollo and Crestwood, in the same enclosure, sometimes painted black - see http://www.freestompboxes.org/viewtopic ... ova#p38121
A third version, with the same 2 transistors, with silicon diodes, a different pcb and different resisistor values exists - an Ebay seller sold off a batch of NOS units of this type this year (2008). Photos of Andy Carrell's one can be seen on the old forum in the post http://dam.10.forumer.com/viewtopic.php ... ght=sekova
fuzz, on Flickr and instagram too
simonm
Re: 2nd version of Sekova 'chrome wedge' fuzz
Post by simonm » Fri Nov 07, 2008 10:23 pm
values
R1 - 27K
R2 - 100R
R3 - 15K
R4 - 5.6K
R5 - 5.6K
R6 - 27K
R7 - 5.6K
R8 - 15K
R9 - 5.6K
R10 - 22K
R11 - 22K
R12 - 68K
C1 - 10uF
C2 - 10uF
C3 - 33uF
C4 - 33uF
C5 - 10uF
C6 - 10uF
C7 - 10uF
C8 - unknown poly
C9 - unknown tant
C10 - 0.001uF
Q1, Q2 - 2SB173
D1, D2 - Ge diodes
Dragonfly
Post by Dragonfly » Mon Nov 10, 2008 8:17 am
SCHEMATIC ...special thanks to our friend Analogguru for reversing it and drawing it up
:party:
simonm
Post by simonm » Mon Nov 10, 2008 8:32 am
Yay - thanks to AG at freestompboxes, above and beyond call of duty etc.
The component numbering on the schematic is different than on my image above, I'll redo it later.
psycho*daisies
Post by psycho*daisies » Mon Nov 10, 2008 7:20 pm
Here's some photos of my two Sekova wedges.
Neither are the version 1 (Maestro FZ-1A copy)
Besides the differences in components, there are a few cosmetic differences.
One has knobs with a clear top with "V" labeled on both,
and the other has solid black plastic knobs with "V" and "T" labels...
I'm guessing the V/V one came first, i think the version 1's had the same knobs...
Last edited by psycho*daisies on Mon Nov 10, 2008 7:46 pm, edited 1 time in total.
If you struggle baby,
It only tightens up...
psycho*daisies
Post by psycho*daisies » Mon Nov 10, 2008 7:22 pm
Sekova circuits..two different versions.
The top one came from the same guy who had a stash of these (where Andy got his from).
Simon, yours looks like a combination of components between these. :smashed:
Yours has the big barrel trannies (like the bottom one here) but with the blue
caps & white tantalum cap like the top one.
Plus yours has different Ge diodes (D1 & D2) than either of these!
the Sekova saga continues...
analogguru
Post by analogguru » Mon Nov 10, 2008 9:16 pm
That´s the same circuit on a slightly modded pcb.
Replace the 27k resistors with 33k, the 5k6 resistors with 4k7 and the Ge-diodes with Si-diodes and you have got it.
I will draw a schematic with the different values later on.
What is written on the transistors of this unit ?
BTW, it has to be Version III and IV. :wink2:
The first version was the Fuzz-Tone clone wired inside like the FZ-1A.
The second version was the same (or similar) circuit with 3 transistors mounted on a pcb - Sir HC has one of them.
analogguru
simonm
Post by simonm » Tue Nov 11, 2008 11:00 am
analogguru wrote:BTW, it has to be Version III and IV. :wink2:
analogguru
I've changed the thread title and some text in the first post...
devnulljp
Re: 2 trannie/9V version of Sekova wedge fuzz (Data Dump)
Post by devnulljp » Thu Mar 19, 2009 1:31 pm
So, do you guys know what this one is?
Sekova Fuzz
3x Matsushita 2SB175 Germanium PNP (?)
Is this the v1 FZ-1 circuit?
analogguru
Post by analogguru » Thu Mar 19, 2009 3:27 pm
Thats v2 of the Sekova Fuzz. v1 was looking inside nearly identical to the Maestro FZ-1A as can be seen in the picture below. If and which changes were made in the v2 couldn´t be determined until now, your guts will be helpfull to achieve that.
I am suspecting that (at least) the Fuzz/Attack potentiometer could be configured like in the Mica Wailer, Fuzzder and other identical units sold under different brand names. BTW, the Mica Wailer and others are derived from the Amplifier Corporation of America (ACA) Fuzz King which used this Fuzz potentiometer configuration first.
An interesting thing is that there is a connection between Sekova and Shin-ei as can be seen on the footswitch of the second picture. There were also sold US-made units under the brand of Sekova as an example the Sekova Sweep (Phase Shifter) like Sir H C has one.
analogguru
