1948 Fender Deluxe amp
Visual and Audio delights of D*A*M and other such noise makers.
Doc Holliday
Re: 1948 Fender Deluxe amp
Post by Doc Holliday »
Doc Holliday
fuzzlounge
Post by fuzzlounge »
^ Wow, what a tone monster, that amp sounds amazing as does the playing!
Doc Holliday
Indeed. I don't know the guy and its def not me lol but great tone right there!
Scott
Post by Scott »
All original tubes. I'll have my amp tech test each tube. Maybe they or one of them is low. I would change out the tubes if that was the problem.
1bottlerocket
Post by 1bottlerocket »
In '48 I think those came with metal can tubes. I am not too familiar with the inner workings of those versions but I am guessing replacing them could give you a boost in performance.
Scott
Post by Scott »
I think you're right. The tubes all have 1948 dates on them. 03-48. Very cool but probably time to retire those and save them.
1bottlerocket
Depending on how often the amp was used it is possible some of the electrolytic caps dried up or drifted out of spec. You may want to check those too. I think it would also be worthwhile to check the voltages being put out by the power transformer too. My 18 watt Marshall PT was putting out incorrect voltages so I replaced it with a Mercury Magnetics version and it was a huge jump in performance.
Zuff-1A
Post by Zuff-1A »
Ken Rad 6v6GT tubes.jpg (28.45 KiB) Viewed 3700 times
Sounds great!
Tubes will change tone! Especially 12AX7 (I like best Amperex Buggle Boy)
About 6V6 - if you want sound it more clear / detailed and sparkle use old 40's or 50's Ken Rad 6V6 GT tubes
If more :crackjam: then RCA or Sylvania
Scott
Post by Scott »
Thanks guys for the good ideas. Ill take it to my amp tech and have him thoroughly check it out. :tu:
