Lets talk compressors
Visual and Audio delights of D*A*M and other such noise makers.
ChrisC
Re: Lets talk compressors
Post by ChrisC » Thu Apr 16, 2009 1:47 am
Try Pedalgeek
says they have one in stock
redeyeflight
Post by redeyeflight » Thu Apr 16, 2009 7:23 am
I used to have the analogman bi-comprosser...I wasn't super impressed...maybe it's just cause I kinda don't like what compressors do on guitar...I've heard good things about the dyna comp though...I'll bet the Cap'n knows what he's talking bout!!! :!:
1bottlerocket
Post by 1bottlerocket » Thu Apr 16, 2009 8:20 am
redeyeflight wrote:I used to have the analogman bi-comprosser...I wasn't super impressed... :!:
What didn't you like about it, specifically? I use mine sporadically but I have had great results with it every time I use it. I am kind of moving away from using compressors when I play but usually plug one in if I am recording. I am interested to hear your take.
1bottlerocket
Post by 1bottlerocket » Thu Apr 16, 2009 8:24 am
dazed and confused wrote:The Dynacomp is certainly a great compressor. Also great are Orange Squeezers, once you get em set up :tu:
I am currently borrowing this. It is the best Compressor I have ever used:
I want........If only I could find one.
Pedal Geek has them for 259, delivered.
dazed and confused
Post by dazed and confused » Thu Apr 16, 2009 8:36 am
Oh cool, thanks man :tu: I'll drop em I line.
The rectifier is great too in this one. A very flexible compressor.
redeyeflight
Post by redeyeflight » Thu Apr 16, 2009 9:21 pm
It robbed me of my high end and it added a bit too much noise for my taste (which I know is something compressors do by nature). I think its a cool pedal...I liked the OS side much more but it just didn't have the "pop" of a dynacomp to my ears...I dunno, like I said, I just think I don't really like compressors in general. The bi-comp will probably make most pretty happy...I just didn't dig it for my sound. In comparison, I thought a demeter compulator was much more transparent and didn't take my high end away. I think a lotta folks will like that slight fattening/smoothing of the highs that the analogman gives your tone but I just don't dig it...
1bottlerocket
Post by 1bottlerocket » Thu Apr 16, 2009 9:41 pm
That's interesting. Which pickups/guitars do you regularly use? I primarily use strats and P90 equipped guitars. Pretty much all the pickups I have are 'vintage' voiced and by that I mean they are relatively low output under 6k, by today's standards, while my favorite set measures 4.9, 5.3, 5.8. I really didn't loose a lot of top end with my rigs and I did notice the smoothing out of the tonal range, as you mentioned. This can go to an extreme too which is why I tend to limit my use of compressors. I also noticed that I play more carefully now that I have weaned myself off compressors.
I also agree, that both models could be more transparent but I think that both Keeley and Analogman are sort of putting their signature stamp on the tone with these compressors.
Interesting, thanks for the reply.
redeyeflight
Post by redeyeflight » Fri Apr 17, 2009 6:01 am
yeah...I use a similar setup...tele w/ stock lower output PU's and a SG w/ p-90's. Def not a bad pedal by any means but i just didn't like the overall tone...I always crave more treble...a TS-9 is waaaay too warm for my tastes. Just my personal opinion. You could do a lot worse than a bi-comp that's for sure!!
devnulljp
Post by devnulljp » Fri Apr 17, 2009 6:32 am
Last boutique-ish compressor I had was an Analogman compROSSor...not the bicomp just the Ross circuit. It was quite quiet for a compressor but just didn't grab me at all. I had convinced myself my old DC was too noisy so I sold it :doh:
Bought another early block logo -- a player, modded for TB, with a 9V power jack. Great.
NewarkWilder
Post by NewarkWilder » Thu Jun 04, 2009 4:20 am
I'm a big big big fan of the BJF Pine Green... I generally play with it off but when i want compression its there, when i want a boost, its there, when i want some simple tone enhancement or whatever, yeah its in there too... so much nuance in the "body" knob, a lot of the pedal's range gets overlooked. the full on ross style squash if you want it but it can be extremely subtle and tasteful as well... definitely spendy for a comp but now that i have it i wouldn't really even consider trying another one
(unless a d*a*m dyna-comp surfaced, of course :hihi:)
