Show off your builds!
Dr Tony Balls
Re: Show off your builds!
Post by Dr Tony Balls »
Data dump.
All red Super Black:
Image Image
Moon Unit delay & verb:
BF-15 combo. 2 x EL84, 15 watt amp with preamp in the 60's Fender vein. Lots of clean, lots of chime, and grit if you wanna crank it. 1x12 combo with a Jensen C12N. Added post-phase inverter master volume to keep it chill when needed:
BF-15+ combo. Really very similar amp to the one posted above but with a tip in the other direction. No master volume, but an added and switchable Rangemaster/Ballsmaster style boost to the front end. Plays the same as if you had a RM pedal or amp-top unit in front of the input, but all internal. Transistor is a Soviet MЛ38a.
Post by daCod »
So. Fekkin. Gnar.
squarewave
Post by squarewave »
Holy crap dude
Radiotron
Post by Radiotron »
That's some amazing work there Tony! Absolutely love the built in rangemaster!
Dr Tony Balls
THANKS!
Jim Goad
Post by Jim Goad »
Voomp!
This had been a wall hanger in a bar or venue for years and was covered in crud and falling apart. I only hung on to it because of the ‘Okay Hot-Shot Okay’ artwork.
70s Jedson pickup, 70s Japanese bridge, 70s Shaftesbury knobs, 90s Hohner neck bolted to a reclaimed pine centre block. It’s crude and rude but plays and sounds ace.
Dr Tony Balls
Kinda more of the same, but this one has reverb and a mid control. A rather loud 15 watts from 2 EL84s, 60's Fender-ish preamp, modified reverb circuit, LarMar type master volume, and a Jensen C12N. On its way to Milwaukee!
Radiotron
Post by Radiotron »
Beautiful work as always!!
One tube reverb?
Dr Tony Balls
Radiotron wrote: Tue May 25, 2021 10:53 pm Beautiful work as always!!
One tube reverb?
Yup. Bit more subtle than the Fender standard but does the job well enough for most needs.
Dr Tony Balls
OTA style Phaser in the vein of Ross / Small Stone but with my tweaks to sweeten it up:
