Page 2 of 3
Re: Dearmond 1800 wah/vol tb mod help
Posted: Thu Feb 18, 2021 12:28 am
by HorseyBoy
^ Yours has definitely been re-wired at some point, Spook. Here's a shot of the guts of my 1800, with the colours as indicated by Brook's image above. Also, as Brook mentioned, completely different PCB!
Posted: Thu Feb 18, 2021 8:18 am
by Spook
peps1 wrote: ↑Thu Feb 18, 2021 12:19 am
Spook wrote: ↑Wed Feb 17, 2021 7:07 pm
Thanks !! You're a life saver :)
OK, different PCB layout to the one I have, give me a little time to reverse engineer it so I don't post a tutorial on how to break a Dearmond 1800
Posted: Thu Feb 18, 2021 8:21 am
by Spook
HorseyBoy wrote: ↑Thu Feb 18, 2021 12:28 am
Woah, weird... If it has, its a very tidy job.
Just my luck...
Posted: Thu Feb 18, 2021 8:26 am
by Spook
Looking online i found more with "my" colours, so maybe different versions.
Posted: Thu Feb 18, 2021 9:16 am
by Spook
Does yours have a date stamp ?
mine says jan 14 1977.
Posted: Thu Feb 18, 2021 9:35 am
by HorseyBoy
There's a faint date stamp on mine (just above the switch) but I can't make it out. Guessing mine might be an earlier version. It has the same El Rad inductor as a Boomer, very similar board.
Posted: Thu Feb 18, 2021 10:05 am
by Spook
looks like mine is a transitional one, with elements of the weeper.
Posted: Sun Sep 12, 2021 11:09 am
by Spook
Bumping this bad boy, i really want to use this with the band...without using a loop pedal
So i need to figure out the wire colors...
Posted: Sun Sep 12, 2021 11:17 am
by Spook
Spook wrote: ↑Wed Feb 17, 2021 12:28 pm
I think i'm screwed keeping the og switch, but i found a dpdt one in my parts box :)
here are some pics, any help in what goes where is much appreciated !
....also on my new switch, there are 3 rows of lugs, on the drawing just 2, do i pick 2 rows on the switch an just leave the other one alone ? does it matter witch rows i use on the new switch ?
by Spook
peps1 wrote: ↑Tue Feb 16, 2021 8:26 pm
If it's the same as the Duovox units you should be able to truebypass it with a DPDT footswitch like this:
But before you cut any wires you may want to post some photos and tell me to double-check!
the drawing with 2 rows
