D*A*M Pedal Registry
- mrpicard
The following provides a registry of the known D*A*M pedals. The format of this registry is: serial number, build date (DD/MM/YYYY), signed by, enclosure description (revision in brackets), transistors, LED type, additional features (each feature separated by a semi-colon, owner name will be in brackets). If you would like your pedal listed in this registry either add a message to this thread or send me a private message. Your member name will be listed as the owner of the pedal unless you specifically ask it to be left out.
The enclosures have undertake lots of obvious and not so obvious changes over the years. To date there have been 5 formal revisions to the Professional MKII enclosures and 3 formal revisions to the 1966 enclosures. Information on these revisions can be found here D*A*M Pedal Descriptions.
As can be seen from this database, D*A*M has produced many "standard" and custom pedals over the years. A second Gallery, the comprehensive D*A*M Pedal Gallery, provides a visual history, in date order, of all those pedals. Information on the all the D*A*M photographic galleries and how to use them can be found here D*A*M Pedal Galleries.
REGISTRY
1965 - Tone Bender MKI Replica
003, 09/07/2007, Dave Main, Grey Hammerite, , No LED, Cream knobs; (dazed and confused)
004, 09/07/2007, Dave Main, Grey Hammerite, , No LED, Cream knobs; (chicagowarmth)
009, 09/07/2007, Dave Main, Grey Hammerite, 1 x Mullard OC71 (Black Glass), 1 x TI 2G381 (Metal Canister), 1 x TI 2G3711 (Metal Canister), No LED, Creme Knobs (Also received a set of Fire Engine Red Knobs); Battery Drawer; (psycho*daisies)
018, xx/07/2007, Dave Main, Grey Hammerite, ,No LED, Super C/'65; Black chicken head knobs; (1bottlerocket)
021, xx/xx/2007, Dave Main, Grey Hammerite, 2 x Texas Instruments 2G381 (Metal Can) / 1 x OC75 (Metal Can), No LED, '65/Super Zee; Black chicken head knobs
1966
006, 20/06/2004, Dave Main, Grey Hammerite, OC76 / OC76, Red LED, AC Power; Press-on dry transfer lettering; White chicken head knobs; Old DAM "Star" logo; (william)
019, 10/03/2005, Dave Main, Grey Hammerite, AC128 / OC76, No LED, Internal trimmer on input; (kb892)
024, 07/07/2005, Dave Main, Grey Hammerite (Rev.2), AC128 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal trimmer on input
031, 27/07/2005, Dave Main, Grey Hammerite, AC128 / OC76, No LED, Internal Trimmer; (SBlue)
033, 05/09/2005, David Main, Grey Hammerite, AC128 (Metal Can, marked W and J7614) / Mullard OC76 (Metal Can), No LED, Internal trimmer
055, 21/03/2006, Dave Main, Gray Hammerite, SFT337 / OC76, No LED, (Tommy1966)
057, 21/03/2006, Dave Main, Gray Hammerite (Rev.2), SFT337 (Metal Can) / OC76 (Black Glass), No LED,
064, 28/03/2006, Linzi, Grey Hammerite, Mullard OC78D / Mullard OC78D, No LED, Marked "Mullard OC78D Special" on the inside; (Sickle)/(stopmaykinsense)
065, 28/03/2006, Linzi, Grey Hammerite , Mullard OC78D (Metal Can), No LED, ""Mullard OC78D SPECIAL. Custom built for Musictoyz.com"; (duende)
066, 01/05/2006, Dave Main, Grey Hammerite, SFT337 (Metal Can) / OC76 (Black Glass, POIAY), No LED, Marked "custom" and "limited edition" on the inside.; (gururyan)
084, 22/06/2006, Linzi, Grey Hammerite (Rev.3), SFT337 (Metal Can) / OC76 (Black Glass), No LED,
085, 22/06/2006, Linzi, Grey Hammerite (Rev.3), SFT337 (Metal Can) / OC76 (Metal Can), No LED, Marked "Limited Edition"
086, 22/06/2006, Linzi, Grey Hammerite, SFT337 (Metal Can) / OC76 (Black Glass), No LED, No internal trimmer; "Custom Built for Axe... and you shall receive."; (Toro Mutanto)
087, 22/06/2006, Linzi, Grey Hammerite, SFT337 (Metal Can) / OC76 (Black Glass, POIAY), No LED, No internal trimmer; Made for Matamp of NZ (i love sharin foo)
095, 16/12/2006, Dave Main, Grey Hammerite, SFT337 (Metal Can) / OC76 (Black Glass, POIAY), No LED, No internal trimmer;
100, 16/12/2006, Dave Main, Grey Hammerite, STF351 (Metal Can) / OC76 (Black Glass), No LED, No internal trimmer
105, 16/12/2006, Dave Main, Grey Hammerite, SFT353 / OC76, , "100% Hand Made by a Real Live Human Being"; (Fuzz-Sound MKIV)
106, xx/12/2006, Dave Main, Grey Hammerite, STF353 / OC76, No LED, Super Z/'66; Black chicken head knobs; (1bottlerocket)
120, 15/05/2007, Dave Main, Grey Hammerite, OC75 / OC76, No LED, No internal trimmer; (SBlue)
122, 15/05/2007, Dave Main, Grey Hammerite, Mullard OC76 (Metal Can) / Mullard OC76 (Metal Can), No LED, No internal trimmer
123, 15/05/2007, Dave Main, Grey Hammerite, OC75 / OC76, No LED,
128, 22/05/2007, Dave Main, Grey Hammerite, Newmarket NKT OC75 (Metal Can, 7351) / Phillips OC76 (Metal Can, 15908), No LED, No internal trimmer; Red knobs; (Topjimi)
129, 13/08/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / Mullard OC76 (Metal Can), No LED, Special 1 of 1; Date incorrectly recorded by Dave as 2008 instead of 2007; States "Special 1 of 1 Mullard OC76"; (chicagowarmth)
132, 17/08/2007, Dave Main, Grey Hammerite, AC125 (Metal Can) / OC76 (Black Glass), No LED,
138, 17/08/2007, Dave Main, Grey Hammerite, Mullard OC78D / Mullard OC78D, No LED, (friendlybunny)
147, 26/09/2007, Dave Main, Grey Hammerite, NKT OC75 / Mullard OC81, No LED, External trimmer on right side; 1 of 5; (Mr. Maestro)
152, 29/09/2007, Dave Main, Grey Hammerite (Rev.3), Newmarket NKT OC75 (Metal Can) / Mullard OC81 (Metal Can), No LED, Internal trimmer; Special 2 of 5
155, 29/09/2007, Dave Main, Grey Hammerite, NKT OC75 / Mullard OC81, No LED, Internal Trimmer; OC81 Special 5 of 5; (kzarifes)
160, 28/01/2008, Dave Main, Grey Hammerite, Mullard OC76 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal Trimmer; (happiass)
162, 28/01/2008, Dave Main, Grey Hammerite (Rev.3), Mullard OC76 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal Trimmer
163, 28/01/2008, Dave Main, Grey Hammerite (Rev.3), Mullard OC76 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal Trimmer
164, 28/01/2008, Dave Main, Grey Hammerite (Rev.3), Mullard OC76 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal Trimmer
171, xx/02/2008, Dave Main, Grey Hammerite, OC76 / OC76, No LED, Super Z/'66; Black chicken head knobs; (1bottlerocket)
174, 11/02/2008, Dave Main, Grey Hammerite (Rev.3), , No LED, (TheHog107)
175, 11/02/2008, Dave Main, Grey Hammerite, OC76 / OC76, No LED, (Cado)
187, 06/12/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / Mullard OC76 (Metal Can), No LED, Internal trimmer; (RC2)
204, 06/12/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / Mullard OC76 (Black Glass), No LED, Internal trimmer; (markom89)
212, 06/12/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / SFT317 (Black Plastic), No LED, Internal trimmer; "Ain't seen a night things work out right, go by"; (smogfalls)
215, 06/12/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / SFT317 (Black Plastic), No LED, Internal trimmer
216, 06/12/2008, Dave Main, Grey Hammerite, SFT353 (Metal Can) / SFT317 (Black Plastic), No LED, Internal trimmer; (dirty finger)
234, 03/06/2009, Dave Main, Sparkly Red & Gold Lettering, CV5429, no LED, "Superer SuperBee mode"; Internal trimmer; (molokaio)
260, 06/09/2010, Dave Main, Psycho Green, OC71 (Black Glass) / OC83 (Metal Can), No LED, Special edition green painted enclosure with "Italian Tone Bender" wording; Internal Trimmer; "The Captain gets confused and fits the wrong board"; (anemochore)
300 Pounds of Fuzz
002, 05/05/2005, Dave Main, Red Enclosure; 5 x Chicken Head Knobs, , , "Fast 'n' Bulbous...Tight Also"; (bazguitar)
Big Daddy (Three Tone Benders in One Pedal)
000, Dave Main, Grey Hammerite with Big Truck Graphic and Red "Big Daddy" Lettering, Mullard OC81D (Metal Can)/Mullard OC81D (Metal Can)/Mullard OC81D (Metal Can); OC75 (Black Glass)/OC75 (Black Glass); AC128 (Metal Can)/Mullard OC76 (Metal Can), No LED, Three Black Knobs (Level/Filter/Attack); White Knob Mode Selector (Angry Wasp-OC76/Super Bee-OC75/Mighty Hornet-OC81D); Angry Wasp is the stock 1966 circuit (closer to the 1966 in Super Bee mode)/Super Bee is a MK1.5 circuit/Mighty Hornet is the MKII circuit; Green Writing "Super Charged Mullard Powered Tone Bender Generator";(Sickle)
Blue Box (MXR Replica)
001, 02/03/2005, Dave Main, Blue, , AC Jack; (kb892)
Corpse Flower - Model 666
1 of 1, 17/11/2004, Dave Main, Red Enclosure with Black Writing, , 2 x LEDs,
Custom Booster
002, 15/09/2007, Dave Main, Werewolf, , , 2 of 4; (kb892)
Drag'n'Fly
010, 18/01/2004, David Main, Red / Large Enclosure, CV7112 / C33716, LED, (SBlue)
023, 12/01/2005, Dave Main, Grey Hammerite, BC107 / 83 (Larger transistor, Unmarked, Metal Can), , (Graham)
030, 06/06/2005, Dave Main, Grey Hammerite, 2N3906 / Mullard OC82DM, LED, (kb892)
032, 27/07/2005, Dave Main, Grey Hammerite, , LED,
034, 28/07/2005, Dave Main, Grey Hammerite (Shiny Knob Heads), , LED,
042, 13/10/2005, Dave Main, Acid Green, , Red LED, (eatighe)
057, 16/03/2006, Linzi, Relic Green, CV7112 / C33716, Red LED, Internal trimmer; (RC2)
065, 04/04/2006, Linzi, Silver Hammerite in Small Enclosure, , Red LED, "Custom Built for Hedix Ltd"; (i love sharin foo)
082, 31/08/2006, , Grey Hammerite, , , (Macdescruple)
115, 21/03/2007, Linzi, Grey Hammerite, CV7112 / C33716, Green LED, Internal trimmer; (kzarifes)
116, 27/03/2007, Linzi, Grey Hammerite, CV7112, Green LED, Internal trimmer; ; "...Only takes half a day to get there if I travel by my Drag'n'Fly"; (BoyMamboII)
121, 27/03/2007, Linzi, Black Enclosure and White Text, CV7112 / BC337-16, Green LED, Internal trimmer; Custom 2 of 4; "I Just Wanna Punch You In The Face"; (JVania)
127, 27/03/2007, Linzi, Grey Hammerite, CV7112 / C33716, Green LED, Internal trimmer
149, 25/11/2007, Linzi, Grey Hammerite, OC139 / ???, Green LED, Standard; (Mr. Maestro)
156, 18/02/2008, Linzi, Grey Hammerite, , , (eatighe)
159, 18/02/2008, Linzi, Grey Hammerite, BC337 / CV7112, Green LED, Internal trimmer; (Philm)
161, 18/02/2008, Linzi, Grey Hammerite, , Green LED, (happiass)
163, 04/02/2009, Linzi, Granny Smith Green, CV7112, Red LED,
166, 04/02/2009, Linzi, Granny Smith Green, CV7112, Red LED, (molokaio)
180, 04/02/2009, Linzi, Granny Smith Green, , , ; (markom89)
233, 29/01/2010, Linzi, Fire Mist, OC140, Red LED, "All I want is 20-20 vision, a total portrait with no omissions"; (Fuzzz)
253, 20/08/2010, Linzi, Trans Copper, , , "Knowledge comes, but wisdom lingers."; (I am Incinerator)
Dyna Comp (MXR Replica)
002, 01/09/2007, Linzi, Red, , No LED, 2 of 6; (Mr. Maestro)
005, 01/09/2007, Linzi, Red, , No LED, 5 of 6; (Sickle)
Elizabeth (Guild Foxey Lady Replica)
002, 03/03/2006, Dave Main, Sonic Blue, , , 1 of 1; (kb892)
Ezekiel 25:17
004, 06/07/2004, Dave Main, Blue, , , 2 Large Black Knobs and 1 Small Black Knob and Red Chicken Head Knob;(SBlue)
008, 25/11/2004, Dave Main, Blue Hammerite, , , 3 Large Black Knobs and one Red Chicken Head Knob; (GTHM)
022, 12/05/2005, Dave Main, Blue Hammerite, , , 3 Large Black Knobs and one Red Chicken Head Knob
029, 16/06/2005, Dave Main, Metallic Blue Finish, , , 3 Chrome Top Knobs & 1 Red Chicken Head Knob;(i love sharin foo)
035, 28/09/2005, Dave Main, "TS" Green, , , Voiced for guitar; Marked guitar #1; (kb892)
042, 06/02/2006, Dave Main, Grey Hammerite, , LED, (Questionable: Contact mrpicard for information)
098, 21/03/2007, Dave Main, Grey Hammerite, , LED,
126, 09/10/2008, Dirt, Grey Hammerite, , LED, (Sickle)
Fuzzaround
000, , Dave Main, Dinosaur Picture - Prototype 1, NKT213's, No LED, (The Captain)
000, , Dave Main, Big Box "Destroyer of Worlds" - Prototype 2, NKT213's, No LED, Knobs on side like original Buzzaround; (The Captain)
000, , Dave Main, Big Box "1 of 1" - Prototype 3, NKT213's, No LED, No tag board; Triangle Knob Layout
001, , Dave Main, Buzzaround Gray, NKT213's, No LED, (kb892)
002, , Dave Main, Black Hammerite, NKT213's, No LED, (Graham)
004, , Dave Main, Black Hammerite, NKT213's, No LED, (the_original_mr_nice)
005, , Dave Main, Black Hammerite, NKT213's, No LED, (markom89)
006, , Dave Main, Black Hammerite, NKT213's, No LED, (Mr. Min T. Fresh)
007, , Dave Main, Black Hammerite, NKT213's, No LED, (1bottlerocket)
008, , Dave Main, Black Hammerite, NKT213's, No LED, (Dazed and Confused)
009, , Dave Main, Black Hammerite, NKT213's, No LED,
010, , Dave Main, Black Hammerite, NKT213's, No LED, (Psycho*Daisies)
011, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (mhat)
012, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (skybone)
013, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (tonebender)
014, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Mr. Maestro)
015, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (chicagowarmth)
016, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (jacobjj5)
017, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (aaland_brian)
018, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Sagezero)
019, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (happiass)
020, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Blobcaster)
021, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Nurket)
022, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Sblue)
023, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Garyrouge)
024, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Pigeontoe)
025, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Cubba)
026, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Eastcoast)
027, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Jp30)
028, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Josoap)
029, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Poorbob)
030, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (LZ_69)
031, , Dave Main, Hammerite Red, NKT213's, No LED,
032, , Dave Main, Hammerite Red, NKT213's, No LED,
033, , Dave Main, Hammerite Red, NKT213's, No LED,
034, , Dave Main, Hammerite Red, NKT213's, No LED,
035, , Dave Main, Hammerite Red, NKT213's, No LED,
036, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (dirty finger)
037, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (sundayfeast)
038, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Tommy1966)
039, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (squarewave)
040, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Emjee)
041, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Ted)
042, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (d4niel)
043, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (slomatic)
044, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (Damn-deal-done)
045, , Dave Main, Pearlescent Amber Metal Flake, NKT213's, No LED, (william)
046, , Dave Main, Hammerite Green, 3 x Mullard OC82Ds with Green Jackets, No LED, (Graham)
047, , Dave Main, Hammerite Green, NKT213's, No LED, (Sickle)
048, , Dave Main, Hammerite Green, NKT213's, No LED,
049, , Dave Main, Hammerite Green, NKT213's, No LED,
050, , Dave Main, Hammerite Green, NKT213's, No LED,
051, , Dave Main, Hammerite Black n Gold, NKT213's, No LED,
052, , Dave Main, Hammerite Black n Gold, NKT213's, No LED, This pedal was made for Linzi as a special work bonus. It is the only D*A*M pedal made for Linzi so this makes it very rare.;(jkranitz)
053, , Dave Main, Hammerite Black n Gold, NKT213's, No LED,
054, , Dave Main, Pearlescent Chrome, NKT213's, No LED,
055, , Dave Main, Pearlescent Brushed Chrome, NKT213's, No LED,
056, , Dave Main, Pearlescent OD Green, NKT213's, No LED,
057, , Dave Main, Pearlescent Bright Fucking Red, NKT OC75s, No LED, (The Captain)
058, , Dave Main, Pearlescent Amber Metal Flake - Defect, NKT213's, No LED,
059, , Dave Main, Pearlescent Amber Metal Flake - Defect, NKT213's, No LED,
060, , Dave Main, Pearlescent Amber Metal Flake - Defect, NKT213's, No LED,
061, , Dave Main, Pearlescent Amber Metal Flake - Defect, NKT213's, No LED,
062, , Dave Main, Pearlescent Amber Metal Flake - Defect, NKT213's, No LED,
FUZZrong
002, 18/12/2007, Dave Main, Grey Hammerite, , No LED, (Mr. Maestro)
005, 19/12/2007, Dave Main, Silver Hammerite, , No LED, (chicagowarmth)
014, 18/12/2007, Dave Main, Punk Pink, OC76 & CV7003 Ge, No LED, (ElectricMudd)
024, 18/12/2007, Dave Main, Silver Hammerite, No LED, 2 x OC76 (Black Glass), Captain Beefheart quote: "The old fart inside was now breathin' freely from his perfume bottle atomizer air bulb invention"; (psycho*daisies)
025, 19/12/2007, Dave Main, Punk Pink, OC76, No LED, Back plate inscription: "When Big Joan Sits Up Her Hands Are Too Small, She's Outta Reach"; (william)
026, 19/12/2007, Dave Main, Red, , No LED, (SBlue)
027, 18/12/2007, Dave Main, Boston Green, , No LED, (kb892)
030, xx/12/2007, Dave Main, Boston Green, No LED, (1bottlerocket)
035, 02/09/2008, Dave Main, Lime Green, AC125 + SFT351 Ge, No LED, (ElectricMudd)
037, 20/06/2008, Dave Main, Lime Green, OC76 + CV7003 Ge, No LED, "Custom Built"
046, xx/xx/xxx, , White, , , (Scott)
Fuzz Sound (Sola Sound MKIII-MKIV Replica)
011, 19/04/2009, Dave Main, Black 'n' Gold, Mullard OC84 (Metal Can) / Mullard OC84 (Metal Can) / Mullard OC45 (Blue Glass), Blue LED, (stopmaykinsense)
Fuzz Sound Mark III (Vox Tone Bender MKIII Replica)
003, 16/02/2006, Dave Main, Yellow, OC74 / OC74 / OC74, No LED, (kb892)
Fuzz Sound Mark IV
1 of 1, 01/09/2007, Dave Main, Small Grey Enclosure, OC81 / OC75, , "100% Hand Made Custom Built for D*A*M Store"; (Fuzz-Sound MKIV)
FZ-673
006, , , Blue, , Red LED, (chetz)
Grease Box GB-80
009, , , Yellow, , Blue LED, (chetz)
Holy Roller
, , Dave Main, Grey Hammerite, , No LED, External trimmer on right side; (kb892)
Meathead
010, 02/08/2004, Dave Main, Purple, 2N3904 / BC107, , (kb892)
015, 05/11/2004, Dave Main, Purple, BC107, No LED, Vero/Perf Board; (psycho*daisies)
026, 10/01/2005, Dave Main, Purple Enclosure with psychedelic graphics, 2N3904 / BC107, No LED, (i love sharin foo)
027, 26/01/2005, Dave Main, Purple Enclosure with Custom Graphics, 2N3904 / BC107, , (SBlue)
034, 12/04/2005, Dave Main, Black Enclosure with light purple Psychedelic Graphics, , , "Custom built with alien tecnology" and an alien head inside; (i love sharin foo)
034, 12/04/2005, Dave Main, Light Purple Enclosure with Psychedelic Graphics, , ,
049, 26/10/2005, Linzi + Dave Main, Sonic Blue, , , DAM Anniversary; (kb892)
058, 01/12/2005, Linzi, Psychedelic with Grey Background and Purple 'Dirt' and 'DAM' Text and Black 'Meathead' Text, , No LED, (Sickle)
091, 16/05/2006, Linzi, Plum Crazy, 2N3904 / BC182L, No LED, (Philm)
105, 31/07/2006, Linzi, Silver Grey Hammer, , , "100% Custom Built For MUSICTOYZ.COM"; (apekillman)
121, 16/11/2006, Linzi, Grey Hammerite with Black Text, , No LED,
126, 16/11/2006, Linzi, Grey Hammerite, ?/BC102L, No LED, (SBlue)
130, 11/12/2006, Linzi, Black Enclosure with Fire Engine Red Daka-ware Chicken Head Knob and White Text, 2N3904 / BC182L, No LED, Custom 1 of 10; "Ah Fuck It Dude. Let's Go Bowling"; (JVania)
134, 11/12/2006, Linzi, Black Enclosure with Fire Engine Red Daka-ware Chicken Head Knob and White Text, , No LED, Custom 5 of 10;
138, 11/12/2006, Linzi, Black Enclosure with Fire Engine Red Daka-ware Chicken Head Knob and White Text, , No LED, Custom 9 of 10; (jkranitz)
148, 26/07/2007, Linzi, "Cherry Pie" consisting of White Enclosure with Fire Engine Red Daka-ware Chicken Head Knob and Cherry Red Text, , No LED, Custom 4 of 5
159, 26/07/2007, Linzi, "Plum Puddin" consisting of White Enclosure, , No LED, Custom 5 of 5; (Fuzzz)
160, 28/08/2007, Linzi, Inca Yellow, BC182L, No LED, Custom 1 of 2; (Tommy1966)
169, 10/10/2007, Linzi, Custom Colour with Floral Motif, , , (eatighe)
176, 05/11/2007, Linzi, Punk Pink, , No LED, "100% Handmade by a Real Live Human Being. Punk Pink 2 of 2"; (Yankee)
178, 05/11/2007, Linzi, "Purple Rain", , ,(Damn-Deal-Done)
185, 12/05/2008, Linzi, Grey Hammerite, , No LED, (Sk10)
192, 12/05/2008, Linzi, Grey Hammerite with Oversized Knob, , No LED, (Sickle)
196, 14/05/2008, Linzi, Grey Hammerite, , No LED, (Decy)
197, 28/08/2007, Linzi, Kingfisher Blue, , , "Custom 2 of 2"; (skybone)
218, 09/07/2008, Linzi, Starlight Blue, , No LED, "Don't worry what people think they don't do it very often"; Colour maybe 1 of 5; (robjrussell)
224, 22/08/2008, Linzi, Grey Hammerite with Custom Red Ink, ,No LED, (h-wing)
225, 22/08/2008, Linzi, Grey Hammerite with Red Text, , , "Life's hard, wear a helmet"; (JP30)
228, 22/08/2008, Linzi, Grey Hammerite with Custom Red Ink, ,No LED,
236, 21/11/2008, Dirt, Black with Gold Lettering and Drawing of a Silly Monster, BC239C / BC184L, No LED, (molokaio)
239, 21/11/2008, Dirt, Black n Gold, , No LED, "I didn't want to scare you guys out of the neighborhood right away"; (i love sharin foo)
247, 21/11/2008, Linzi, Black n Gold, , , "Custom built for D*A*M Store"; "Dave's Not Here"; (apekillman)
248, 21/11/2008, Dirt, Black n Gold, , No LED, "Those who do not want to imitate anything, produce nothing"; (smogfalls)
249, 21/11/2008, Dirt, Black n Gold, , No LED, (happiass)
251, 21/11/2008, Dirt, Black n Gold with with Fire Engine Red Daka-ware Chicken Head Knob, , No LED, Custom Slo-Mod; (Sickle)
261, 16/02/2009, Linzi, Pink Bubblegum, BC182L / BC239C, No LED, (i love sharin foo)
269, 17/02/2009, Linzi, Red Baron with Black Knobs, , , "God damn it, you've got my pen! God Damn Hippies!"; (edoetsch)
273, 17/02/2009, Linzi, Red Baron, BC182C / BC239C, No LED, (i love sharin foo)
279, 17/02/2009, Linzi, Red Baron, BC182L / BC239C, No LED, "Jefferson Airplane "White Rabbit" I Need A Rising Sound..."; (Fuhgawz)
280, 07/12/2009, Linzi, Signac Violet, BC 182L / BC 239C, No LED, "What will ya have! I'll have a pint. I'll have a pint with you sir! This pedal was 10% handmade, 90% she used her teef", (emeka)
306, 22/07/2010, Dave Main, Green, , No LED, "Stand Up, Fight", (arem)
Meathead "Custom"
xxx, 13/04/2008, Dave Main, Naked Woman Drawing, , Red LED, "1 of 1"; (markom89)
xxx, 13/04/2008, Dave Main, Green Naked Woman Drawing, , Red LED, "1 of 1"; (markom89)
Meathead "Dark"
001, 27/03/2009, Linzi, Cherry Sparkle/Black, BC182L / BC239C, , (i love sharin foo)
009, 27/03/2009, Linzi, Cherry Sparkle/Black with Drawing of a lil Spider, BC182L / BC239C, No LED, (molokaio)
Meathead "Flesh"
001, 04/02/2008, Dave Main, Silver Hammerite with 'Flesh' and 'Dirt' Controls, BC182L / T2N3904, No LED, (Graham)
003, 04/02/2008, LH + Dave Main, Silver Hammerite with 'Flesh' and 'Dirt' Controls, , No LED, (kb892)
005, 04/02/2008, Linzi + Dave Main, Silver Hammerite with 'Flesh' and 'Dirt' Controls, , No LED, (Sickle)
008, 04/02/2008, Linzi + Dave Main, Silver Hammerite with 'Flesh' and 'Dirt' Controls, 2N3904 / BC182L, No LED, (Philm)
Meathead "Kittyhead"
2 of 2, 08/12/2005, L Haynes, White with "Hello Kitty" graphics, , No LED, Made as part of a Christmas run of pedals in 2005; (happiass)
Meathead Deluxe (Small Enclosure)
000, 29/03/2007, Dave Main, Silver Hammerite with White Text, , Red LED, PCB Version Sickle
007, 16/05/2007, Linzi, Blue / Gray Hammerite, , , (eatighe)
008, 14/02/2006, Dave Main, Grey Hammerite, , Blue LED, (kzarifes)
018, 23/05/2007, Dave Main and Linzi, Custom Blue with White Text, AC176 / AC176, Blue LED, PCB Version; (william)
019, 18/03/2008, Linzi, Grey Hammerite with British Knobs, , Red LED, PCB Version; (i love sharin foo)
022, 18/03/2008, Linzi, Grey Hammerite with British Knobs, , Red LED, PCB Version; (happiass)
Meathead Deluxe (Large Enclosure)
003, 21/11/2005, Dave Main, Fire Engine Red, , Blue LED, (fortran106)
004, 22/11/2005, Dave Main, Grey Hammerite with Purple Text and D*A*M Text in Blue, , Blue LED, (Sickle)
007, 14/02/2006, Dave Main, Purple, , , (skybone)
010, 28/02/2006, Dave Main, Grey Hammerite with Purple Text and D*A*M Text in Blue, Germanium OC81D, Blue LED, "OC81D 1 of 1"
029, 08/04/2008, , , , , (Emjee)
046, 07/12/2006, Linzi, Large White Enclosure, T2N3904 / BC182L, , (SBlue)
049, 07/12/2006, Linzi, White, , , (kb892)
051, 07/12/2006, Linzi, White Enclosure with text in Cherry Red, , Red LED, "100% Handmade By A Real Live Human Being"; (apekillman)
055, 26/03/2009, Dave Main, Metallic Black/Multi-Coloured Sparkle, , Blue LED, (smogfalls)
064, 26/03/2009, Dave Main, Metallic Black/Multi-Coloured Sparkle, , Blue LED, (markom89)
Meathead Deluxe (Donnerbox Nebula Series)
1 of 10, 06/06/2006, , Donnerbox Green Nebula, , ,
2 of 10, 06/06/2006, , Donnerbox Purple Nebula, , , (pigeontoe)
3 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
4 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
5 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
6 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
7 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
8 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
9 of 10, 06/06/2006, , Donnerbox Purple Nebula, , ,
10 of 10, 06/06/2006, , Donnerbox Green Nebula, , ,
MK1.5
---, --/--/--, Hand Built by Dave Main in 2007 (No Signature), Grey Hammerite (Sola Sound MKII Professional Sandcast R/I Enclosure), 2 x Mullard OC71's (Black Glass), No LED, Mustard Caps; Vero Board; D*A*M "Eye" Sticker on Bottom Plate (outside); (psycho*daisies)
MXR Phase 100
004, 25/01/2004, David Main, Red Enclosure, , , Custom build; 4 of 4; Genuine '70's MXR circuit board; (Damn-Deal-Done)
PRO 808
000, 21/05/2005, David Main, Green, , Custom one of; (SBlue)
Professional Fuzz Sound Mark III
007, 14/04/2009, David Main, Black 'n' Gold, Mullard OC84 / Impex S3-1T / Mullard OC84, Blue LED, (Sk10)
009, 14/04/2009, David Main, Black 'n' Gold, Mullard OC84 (Metal Can) / Mullard OC84 (Metal Can) / Mullard OC45 (Blue Glass), Blue LED, (smogfalls)
Professional MKII
---, 08/12/2004, Dave Main, Grey Hammerite (Sola Sound MKII Professional Sandcast R/I Enclosure),
3 x Mullard OC81D's (Metal Cans), No LED, Mustard Caps; Vero Board; "1965 Mullard OC81D Special"; (psycho*daisies)
007, 20/09/2004, Dave Main, Grey Hammerite, Mullard OC80 (White Glass) / Mullard OC80 (White Glass) / Mullard OC80 (White Glass), No LED, No Internal Trimmer; Mustard Capacitors; No Battery Drawer; Dry Letter Transfers; (John Paul McBain)
014, 26/01/2005, Dave Main, Grey Hammerite, Mullard OC81D (White Glass) / Mullard OC81D (White Glass) / Mullard OC81D (White Glass), No LED, No Internal Trimmer; Mustard Capacitors; White Chicken Head Knobs; (dazed and confused)
024, 04/04/2005, Dave Main, Grey Hammerite, OC81D / OC81D / OC81D, No LED, No internal trimmer; (kb892)
033, 29/04/2005, Dave Main, Gray Hammerite, OC75 / OC75 / OC75, No LED, Mustard Caps; (Tommy1966)
044, 01/06/2005, Dave Main, Grey Hammerite , Mullard OC81D (Metal Can), No LED, "Mullard OC81D SPECIAL. Custom built for Axe and You Shall Receive"; (duende)
054/ 28/07/2005, David Main, Grey Hammerite, OC81D (Metal Can) / OC81D (Metal Can) / OC81D (Metal Can), No LED, Mustard Caps; No internal trimmer; Black chicken head knobs; (1bottlerocket)
055, 10/08/2005, David Main, Grey Hammerite, OC81D (Metal Can) / OC81D (Metal Can) / OC81D (Metal Can), No LED, Mustard Caps; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; Back plate inscription: "Born At 18:20pm 74.8F 'OC81D' Special"; (william)
056, 10/08/2005, Dave Main, Grey Hammerite, OC81D (Metal Can) / OC81D (Metal Can) / OC81D (Metal Can), No LED , Mustard Caps; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; Back plate inscription: "Born At 18:20pm 74.8F 'OC81D' Special"; (william)
059, 06/09/2005, Dave Main, Grey Hammerite, Mullard OC81D (White Glass) / Mullard OC81D (White Glass) / Mullard OC81D (White Glass), No LED , Mustard Caps; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; Back plate inscription: "'Mullard OC81D Special"
060, 06/09/2005, Dave Main, Grey Hammerite, Mullard OC81D (White Glass) / Mullard OC81D (White Glass) / Mullard OC81D (White Glass), No LED , Mustard Caps; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; Back plate inscription: "'Mullard OC81D Special"; (AGuitarPlayer)
061, 06/09/2005, Dave Main, Grey Hammerite, Mullard OC81D (White Glass) / Mullard OC81D (White Glass) / Mullard OC81D (White Glass), No LED, No Internal Trimmer; Mustard Capacitors
066, 03/11/2005, Dave Main, Grey Hammerite, Mullard OC81DM (Metal Can) / Mullard OC81DM (Metal Can) / Mullard OC81DM (Metal Can), No LED, No Internal Trimmer; Mustard Capacitors; "Mullard OC81DM Special"; (jkranitz)
066, 03/11/2005, Dave Main, Grey Hammerite, Mullard OC81D (White Glass) / Mullard OC81D (White Glass) / Mullard OC81D (White Glass), No LED, No Internal Trimmer; Mustard Capacitors; "Mullard OC81D Special. Re-Bias/New Switch/Service 13/11/2008"; (jkranitz)
067, 03/11/2005, Dave Main, Grey Hammerite, Mullard OC81DM (Metal Can) / Mullard OC81DM (Metal Can) / Mullard OC81DM (Metal Can), No LED, No Internal Trimmer; Mustard Capacitors
072, 07/12/2005, Dave Main, Grey Hammerite, Mullard OC82DM / Mullard OC82DM / Mullard OC82DM, , + DC; (SBlue)
073, 07/12/2005, Dave Main, Grey Hammerite, Mullard OC81D (Metal Can) / Mullard OC81D (Metal Can) / Mullard OC81D (Metal Can), No LED, No Internal Trimmer; Mustard Capacitors; "OC81D Special"
078, 14/12/2005, Dave Main, Grey Hammerite, Mullard OC81D (Metal Can) / Mullard OC81D (Metal Can) / Mullard OC81D (Metal Can), No LED, No Internal Trimmer; Mustard Capacitors; "OC81D Special"
141, 31/07/2006, Dave Main, Grey Hammerite, OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer; "Bias Set: 9.7v@21.8 Degrees Celsius"
143, 31/07/2006, Dave Main, Grey Hammerite, OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer; "Bias Set: 9.7v@21.8 Degrees Celsius".
163, 16/12/2006, Dave Main, Grey Hammerite, OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer
166, 16/12/2006, Dave Main, Grey Hammerite, OC75 / OC75 / OC75, No LED, Black chicken head knobs; Red D*A*M sticker on inside back plate; (AGuitarPlayer)
171, 16/12/2006, Dave Main, Grey Hammerite, OC75 / OC75 / OC75 , , (Fuzz-Sound MKIV)
174, 16/12/2006, Dave Main, Grey Hammerite, OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer; (cali68)
183, 16/12/2006, Dave Main, Grey Hammerite (Rev.5), Originally OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) however later replaced with Mullard OC81D (Metal Can) / Mullard OC81 (Metal Can) / OC81 (Metal Can), No LED, The original transistors and internal trimmer have been replaced and there has been some re-wiring and re-soldering. This work was not done by Dave Main and was completed by an unknown party.
184, 16/12/2006, Dave Main, Grey Hammerite (Rev.5), OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer
189, 26/03/2007, Dave Main, Grey Hammerite (Rev.5), OC75 (Black Glass) / OC75 (Black Glass) / OC75 (Black Glass) , No LED, Standard; Internal Trimmer
198, 15/05/2007, Dave Main, Grey Hammerite, OC75 / OC75 / OC75, No LED, Standard; (Mr. Maestro)
210, 17/10/2007, Dave Main, Grey Hammerite, Mullard OC81 (Metal Can, 2N1) / Mullard OC81 (Metal Can, 2N1) / Mullard OC81 (Metal Can, 2S3), No LED, Internal trimmer; Marked "Mullard OC81 LTD.ED 1 of 1"
213, 17/10/2007, Dave Main, Grey Hammerite, Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass), No LED, Internal trimmer; Marked "Special Low Gain 1 of 2" (Sickle)
214, 17/10/2007, Dave Main, Grey Hammerite, Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass), No LED, Internal trimmer; Low Gain; Marked 2 of 2; (kb892)
219, 17/10/2007, Dave Main, Grey Hammerite (Rev.5), OC71 / OC71 / OC71, No LED, (skybone)
220, 07/11/2007, Dave Main, Grey Hammerite (Rev.5), Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass), No LED, Internal trimmer
221, 07/11/2007, Dave Main, Grey Hammerite, OC75 / OC75 / OC75, No LED, (chicagowarmth)
233, 01/08/2008, Dave Main, Grey Hammerite, OC75 (Black Glass) / OC75 (Black Glass)/ OC75 (Black Glass), No LED, (happiass)
236, 01/08/2008, Dave Main, Grey Hammerite, Mullard OC75 (Black Glass) / Mullard OC75 (Black Glass) / Mullard OC75 (Black Glass) , NO LED, Internal trimmer
240, 01/08/2008, Dave Main, Grey Hammerite, Mullard OC75 / Mullard OC75 / Mullard OC75, NO LED, (Cado)
244, 01/08/2008, Dave Main, Grey Hammerite, Mullard OC71 (Black Glass) / Mullard OC71 (Black Glass)/ Mullard OC71 (Black Glass), NO LED,
247, 12/08/2008, Dave Main, Grey Hammerite, Mullard OC75 (Black Glass) / Mullard OC75 (Black Glass) / Mullard OC75 (Black Glass), NO LED,
248, 12/08/2008, Dave Main, Grey Hammerite, Mullard OC82D (Green Glass) / Mullard OC82D (Green Glass) / Mullard OC82D (Green Glass), NO LED, Internal Trimmer; (Sickle)
250, 12/08/2008, Dave Main, Grey Hammerite, Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass) / Valvo OC71 (Black Glass), No LED, Internal trimmer
253, 12/08/2008, Dave Main, Grey Hammerite, NKT OC75 (Metal Can) / NKT OC75 (Metal Can) / NKT OC75 (Metal Can), No LED, Internal trimmer; "NKT075 1 of 2";(1bottlerocket)
276, 03/07/2009, Dave Main, Translucent Copper, NKT OC75 (Metal Can) / NKT OC75 (Metal Can) / NKT OC75 (Metal Can), No LED, Internal trimmer; (stopmaykinsense)
321, 04/12/2009, Dave Main, Grey Hammerite, AC125s, No LED, "You understand, Captain, that this mission does not exist, nor will it ever exist..."; (emeka)
Professional MKII (Sola Sound)
, 05/05/2009, David Main, Grey Hammerite, Mullard OC84 (Metal Can) / Mullard OC84 (Metal Can) / Mullard OC84 (Metal Can), No LED, Gutted by Dave Main; (anemochore)
10011216, , Dave Main, , OC84 / OC84 / OC84, , (I am Incinerator)
Ram Head
002, 14/10/2005, Dave Main, Large Acid Green Enclosure with Red Text, , , (chicagowarmth)
005, 10/01/2006, Linzi, Large White Enclosure with Red Text, , ,
020, 29/05/2006, Linzi, Large White Enclosure with Black Text, , , Vero board version
021, 29/05/2006, Linzi, Large Optical White Enclosure, , , "100% Hand Made, Custom Built for Musictoyz.com"; (i love sharin foo)
022, 29/05/2006, Linzi, Large White Enclosure, , , PTP; (SBlue)
025, 26/04/2007, Dave Main, Custom White, 4 x BC239C, LED, Small Box; PCB Version; (Tommy1966)
025, 29/05/2006, Linzi, Large White Enclosure, BC182L, , "100% Hand Made, Custom Built for Musictoyz.com"; (Fuzz-Sound MKIV)
028, 14/05/2007, Linzi, Small Blue Enclosure, BC239, , "100% Hand Made"; PCB Version; (Fuzz-Sound MKIV)
029, 29/05/2005, Linzi, Large White Enclosure with Black Text, , Red LED , "100% Hand Made, Custom Built for Vintage and Rare Guitars"
034, --/--/2006, Linzi, Large Enclosure in "Optical White" with Black Text, , Red LED, Made for Matamp NZ; (markom89)
041, 10/06/2006, Dave Main, Large White Enclosure with Black Text, 4 x BC239B, Red LED, "100% handmade by a real live human being"; (tekbow)
060, 23/10/2006, Linzi + Dave Main, Large White Enclosure with Black Text, , Red LED, (Sickle)
073, 12/12/2006, Dave Main, Large White Enclosure with Black Text, 4 x BC239B, Red LED, (GTHM)
076, 12/12/2006, Dave Main, Large White Enclosure, , , (eatighe)
088, 25/11/2007, Dave Main, Enchanted Green, 4 x BC239C (CBE), , 4 of 4; (Graham)
089, 01/12/2007, Dave Main, Purple Rain, BC239C, Blue LED, Standard; (Roady)
092, 17/08/2007, Dave Main, Small Black Enclosure with White Text and EH-Type Knobs, , , PCB version; (Sickle)
092, 04/01/2008, Dave Main, Large Green Enclosure with Black Text and EH-Type Knobs, ,Red LED, (happiass)
093, xx/01/2008, Dave Main, Enchanted Forest, BC239C, Red LED, Black Dakaware knobs; (1bottlerocket)
095, 17/08/2007, David Main, Black Small Enclosure with White Text, , , PCB Version; (Damn-Deal-Done)
Red Rooster
008, 10/08/2003, Dave Main, Red, , , (dazed and confused)
029, 04/08/2004, Dave Main, , OC44, No LED, This pedal has a transistor socket and is currently loaded with a Mullard OC45. Has original OC44, a Mullard OC81D, and an additional OC44 that can be switched out. All four transistors make the pedal sound and react completely different.; (Tommy1966)
038, 07/06/2005, Dave Main, Red, AC176, , (kb892)
055, 18/01/2006, Linzi, Grey Hammerite, , Red LED , Internal trimmer
138, 17/04/2007, , Grey Hammerite, , , (Macdescruple)
140, 17/04/2007, Linzi, Grey Hammerite, CV7112, Red LED, "Its all the same no matter where you are"; (duende)
145, 29/09/2007, Linzi, Black 'n' Red, CV7112, LED, (Tommy1966)
163, 10/10/2007, Linzi, Grey Hammerite with Red Text, OC140 (5R51), Red LED, Internal trimmer; (GTHM)
151, 29/09/2007, Linzi, Grey Hammerite with Red Text, CV7112, Red LED, Standard; (Mr. Maestro)
173, 29/04/2008, Linzi, Grey Hammerite, , , (devnulljp)
175, 05/05/2008, Linzi, Grey Hammerite with Red Text, CV7112, Red LED, Standard;
183, 05/05/2008, Linzi, Grey Hammerite with Red Text, CV7112 (Glass), Red LED, (i love sharin foo)
195, 24/07/2008, Linzi, "Starlight Red" consisting of Sparkling Red Enclosure with Tan Text, 1970s OC140 (Metal Can), Red LED, (jkranitz)
204, 24/07/2008, Linzi, "Starlight Red" consisting of Sparkling Red Enclosure with Tan Text, 1970s OC140 (Metal Can), Red LED, (Sickle)
207, 24/07/2008, Linzi, "Granny Smith Green" consisting of Green Enclosure with Red Text, 1960s OC140 (Metal Can), Red LED, (ElectricMudd)
213, 06/03/2009, Linzi, "Starlight Red" consisting of Sparkling Red Enclosure with Gold Text, OC140 (Metal Can), Red LED, "A Cap Of Good Acid Costs Five Dollars And For That You Can Hear The Universal Symphony Of God Singing Solo With The Holy Ghost On Drums"; (JVania)
215, 06/03/2009, Linzi, "Starlight Red" consisting of Sparkling Red Enclosure with Tan Text, , Yellow LED, (smogfalls)
218, 06/03/2009, Linzi, "Starlight Red" with gold text, OC140, , "I'm gonna grow fins 'n go back in the water again"; (Fuzzz)
245, 23/03/2009, Linzi, "Red Baron" consisting of Red Enclosure with Black Text, , Yellow LED, (markom89)
307, 17/07/2010, Linzi, Black, OC42, , "I will sell my soul for something pure and true"; (guitmatt/tigerdriver)
313, 05/08/2010, Linzi, Candy Apple Red, OC71 , , "We're the renegades of this Atomic Age."; (I am Incinerator)
Riffdriver (Colorsound Overdriver Replica)
001, 23/11/2005, Dave Main, Grey Hammerite, BC109C (Metal Can) / BC109C (Metal Can) / BC109C (Metal Can), Red LED, AC Tap; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; Bulgin Battery Clip attached to back cover; Cliff Jacks; Back plate inscription: "Slumber Killed By Rays Of The New Red Sun Arising. Dreamer Wakens To Spectral Gaze Of Light Rays Shining"; (william)
Sonic Titan
003, 14/09/2005, Dave Main, Blue, , , (kb892)
004, 21/10/2005, Dave Main, Blue, , , (Jim Goad)
016, 18/05/2006, Dave Main, Heavy Equipment Yellow, 2N3819 JFET / LM386N-1, Blue LED, Internal trimmer; (RC2)
029, 14/08/2006, Linzi, Sonic Blue, , Blue LED, "Custom Built for Vintage & Rare"; (mezcalhead)
032, 14/08/2006, Linzi, Grey Hammerite, , Blue LED, "Custom Built for Hedix Ltd";
050, 23/11/2006, , , , , (Emjee)
052, 20/11/2006, Linzi, Grey Hammerite, 2N3819 JFET amplifier / LM386N-1, Blue LED, Internal trimmer; (kzarifes)
065, 14/12/2006, Linzi, Small White Enclosure with Black Text, , , Internal trimmer
084, 22/03/2007, Linzi, Grey Hammerite, , Blue LED,
087, 22/03/2007, Linzi, Grey Hammerite, , Blue LED, Standard; (Mr. Maestro)
097, 03/08/2007, Linzi, Grey Hammerite, 2N3819 / LM386N IC, Blue LED, Internal trimmer; (Philm)
115, 19/10/2007, Linzi, Grey Hammerite, 2N3819 JFET amplifier / LM386N-1, Blue LED, Internal trimmer; (GTHM)
124, 06/11/2007, Linzi, African Violet, 2N3819 / LM386N-1, , 4 of 4; (Graham)
125, 25/11/2007, Linzi, Grey Hammerite, LM386N-1, Blue LED, (SBlue)
129, 20/02/2008, Linzi, Grey Hammerite, , Blue LED, (Questionable: Contact mrpicard for information)
132, 20/02/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (chicagowarmth)
144, 06/06/2008, Linzi, "Starlight Blue" with White Lettering (Small Enclosure), 2N3819 / LM386N-1, Blue LED, (molokaio)
150, 06/07/2008, Linzi, "Starlight Blue" (Small Enclosure), 2N3819 / LM386N-1, Blue LED, (Sickle)
157, 18/02/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (TheHog107)
163, 20/06/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (i love sharin foo)
168, 20/06/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (Sk10)
169, 20/06/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (imlikeajungle)
178, 05/07/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (jkranitz)
183, 05/07/2008, Linzi, Grey Hammerite (Small Enclosure), , Blue LED, (happiass)
202, 10/04/2009, Linzi, Metallic Silver, , Red LED, "Strange Days Have Found Us"; (Fuhgawz)
205, 10/04/2009, Linzi, Metallic Silver, , Red LED, (i love sharin foo)
223, 24/09/2009, Linzi, Silver Sparkle, , , "What You Running From!"; (Fuzzz)
239, 02/07/2010, Linzi, , , , "As we watch it all come falling down"; (Dudewater)
249, 07/12/2009, , Very Pink, , , (Macdescruple)
Super Bee
023, 02/10/2009, Linzi, Metallic Orange, OC41 & OC78, Green LED, "The Production Is Progress But The Reason Is Retro"; (Fuzzahead)
070, 06/04/2010, Linzi, Starlight Red, OC78D & OC42, , "Waiting For the ships to turn on the tide"; (Fuzzz)
Super Bee SB66
121, 24/03/2004, Linzi, , , , "Freedom is someting that dies unless it is used."; (I am Incinerator)
158, 01/10/2011, Linzi, , , , "The more you achieve and the better you do, the more you have to live up to"; (Fuzzz)
176, 06/11/2011, Linzi, AC125 (Metal Can) / AC125 (Metal Can), Bug eyes, "The dogs may bark but the caravan moves on"; (anemochore)
Super Bee (MKI.5 Replica)
001, 31/06/2004, Dave Main, Yellow, OC75 / OC75, LED, AC Jack; 1 of 1; (kb892)
Super Bee MKII
1 of 1, 10/07/2007, Dave Main, Small Grey Enclosure, AC176, , "100% Hand Made by a Real Live Human Being"; (Fuzz-Sound MKIV)
Super C (Fuzz Face W "Mayer Hendrix Mods")
001, 14/02/2004, Dave Main, Grey Hammerite, AC128 / AC128, No LED, 1 of 1; (kb892)
Super Pro MKII
002, 11/03/2008, Dave Main, Grey Hammerite, OC75s, No LED, 2 of 2; Level/Drive/Attack Knobs
Toasted Cheese Sandwich
001, 21/02/2006, Linzi + Dave Main, , , , Lovetone Big Cheese clone; Custom 1 of 1; (chicagowarmth)
The Troll (AB/Y looper)
001, 19/11/2005, Dave Main, Green Enclosure with Black Writing, , 3 x LEDs (Red/Yellow/Green), (Mr. Min T. Fresh)
Unidrive UD50 Replica
001, 15/02/2006, Dave Main, Grey Hammerite, Tx C732 6H / Tx C732 6H / Tx C732 6H, Blue LED, AC Tap; Cliff Jacks; Black chicken head knobs; DAM "Seeing Eye" Medallion Logo; (william)
Shin-Ei Companion/FY-2 Replica
001, 05/03/08, David Main, Grey hammerite, Custom Minotaur graphic, 2x BC209, Blue LED, Custom 1 of 2; (Mr. Min T. Fresh)
REGISTRY
1966
300 Pounds of Fuzz
Custom Booster
Drag'n'Fly
Ezekiel 25:17
Fuzzaround
FUZZrong
Fuzz Sound Mark IV
FZ-673
Grease Box GB-80
Holy Roller
Meathead
Meathead "Custom"
Meathead "Dark"
Meathead "Flesh"
MK1.5
MXR Phase 100
PRO 808
Professional MKII
Ram Head
Red Rooster
Sonic Titan
Super Bee
Super Bee SB66
Super Bee MKII
Super Pro MKII
- psycho*daisies
Re: D*A*M Pedal Registry
Hey mrpicard, for the DAM registry,
...posting a message because PMs only allow one attachment each.
MKII
No serial #, 08/12/2004, D. Main, Grey Hammerite, Sola Sound MKII Professional sandcast R/I enclosure,
3 x Mullard OC81D's (metal cans), No LED, mustard caps, vero board, "1965 Mullard OC81D Special"
MK1.5
No serial #, No build date, No signature, (hand built by D. Main, 2007), Grey Hammerite, Sola Sound MKII Professional sandcast R/I enclosure, 2 x Mullard OC71's (black glass), No LED, mustard cap, vero board, DAM "eye" sticker on bottom plate (outside)
MKII
MK1.5
- DAMMkIIGUTZ.jpg (65.68 KiB) Viewed 25559 times
- DAMmkIISIG.jpg (65.32 KiB) Viewed 25554 times
- DAMmkII65OC81Dspecial.jpg (66.03 KiB) Viewed 25551 times
- DAMMk1.5GUTZ.jpg (61.66 KiB) Viewed 25553 times
If you struggle baby,
It only tightens up...
- psycho*daisies
FUZZrong
024, 18/12/2007, D. Main, silver hammerite, no LED, 2 x OC76 (black glass)...i think, will verify tonight...
Captain Beefheart quote, "the old fart inside was now breathin'..."
- DAMfuzzRONG#24.jpg (104.62 KiB) Viewed 25539 times
- psycho*daisies
Meathead
015, 05/11/2004, D. Main, purple, BC107, vero/perf board, No LED
- DAMmeathead#15top.jpg (85.77 KiB) Viewed 25514 times
- DAMmeathead#15.jpg (106.13 KiB) Viewed 25512 times
- markom89
Thanks a bunch for doing this!
I'm actually the owner of Fuzzaround #5. Was Dave's, but I traded spots :D
I also own a Ramhead, but I forget the number off the top of my head. It's one of the old big white ones and says something about Matamp inside. Will get back tomorrow.
EDIT: Back w/ Ramhead info!
2006 'large box' (white) Ram Head #034. Made for Matamp NZ... signed Linzi.
I have a Hammerite Red Rooster built by Linzi.
No 173
Date 29/04/2008
(and a neater soldering & wiring job I have never seen)
Should I take the fortune cookie philosophy inside to heart?
No 173
Date 29/04/2008
- mrpicard
:-)markom89 wrote:Thanks a bunch for doing this!
Sorry guys for being late on the updates but I have only just noticed these entries!! For some reason I am not getting an topic notifications...but weird... Anyway, everything is entered in the registry and the photos are in the photo registry. Thanks again, nice looking pedals :-)
- happiass
Well, I've been putting this off for about a year but here are mine:
Sonic Titan
#183, 5/7/2008, Linzi, Silver Hammerite, Blue LED
Drag'n'Fly
#161, 18/2/2008, Linzi, Silver Hammerite, Green LED
Ram Head
#092, 04/01/2008, D. Main, Green, Red LED
MK II
#233, 01/08/2008, D. Main, Silver Hammerite, OC75's
1966
#160, 28/01/2008, D. Main, Silver Hammerite, 2 metal can Mullard OC76's
Fuzzaround
#019, 02/10/2008, D. Main, Pearlescent Amber Metal Flake, NKT213's
Black & Gold Meathead
#249, 21/11/2008, Dirt, Black and Gold
Meathead (Kittyhead)
#2 of 2, 08/12/2005, Linzi (signed as L. Haynes), White with "Hello Kitty" graphics; made as part of a Christmas run of pedals in 2005.
Meathead Deluxe
#022, 18/3/2008, Linzi, Silver Hammerite , Red LED
Sonic Titan
Drag'n'Fly
Ram Head
MK II
1966
Fuzzaround
Meathead Deluxe
- DAM.jpg (318.73 KiB) Viewed 24847 times
- happiass
Gut Shots:
- Fuzzaround
- Fuzzaround.jpg (381.66 KiB) Viewed 24833 times
- 1966
- 1966.jpg (343.5 KiB) Viewed 24824 times
- MK II
- MK II.jpg (332.84 KiB) Viewed 24822 times
- Ram Head
- IMG_0075.jpg (345.41 KiB) Viewed 24812 times
- Drag'n'Fly
- Dragnfly.jpg (298.46 KiB) Viewed 24807 times
- Titan
- IMG_0073.jpg (291.75 KiB) Viewed 24787 times
- happiass
Last two. Sorry about all the photos. As I said, I've been putting this off awhile. Thank you for all your effort in doing this mrpicard.
- Meathead Deluxe
- Meat Deluxe.jpg (339.42 KiB) Viewed 22797 times
- Kittyhead
- Kittyhead.jpg (329.48 KiB) Viewed 22794 times
Users browsing this forum: No registered users and 10 guests
