which batteries 'are good' for the meathead?
for the old fuzz I read that are better the old carbon, and I would like to know if it's true also for the Meathead.
as always
Fuzz ON
Meathead Battey?
- ufoclub
- ufoclub
Re: Meathead Battey?
thanks
I'll looking for the 'zinco carbone' on the web, because in my local store have only the alkaline.
FuzzON
FuzzON
- thesjkexperience
If your in the States check the dollar bin at Target as they have the carbon/zinc batteries about twice a year. If you have a PP2 you can run on plug 1 or 2 and sag it a bit and you're pretty close.
Steal a little and they throw you in jail. Steal a lot and they make you a King. -- Bob Dylan
"ripped out of the sky reforming thought into creation electric motion begins" - Linzi
- ufoclub
thanks but I'm from Italy,thesjkexperience wrote:If your in the States check the dollar bin at Target as they have the carbon/zinc batteries about twice a year. If you have a PP2 you can run on plug 1 or 2 and sag it a bit and you're pretty close.
and I don't use the PowerPedal2
I found this
http://www.camelion.de/primary/green.html
the model 6f22
for italy the cost of spedition are cheap
- the_original_mr_nice
Batteries ? You mean I have to add batteries ?!! I'm still using the ones Dave loaded up at birth and thought they came under his 5 year warrenty...
- meadhead
I thought it ran on blood....
My bad.
My bad.
- ufoclub
maybe you do not play it enough..:)
I have read on the instruction to paly it until your fingers bleed..
