Dearmond 1800 wah/vol tb mod help
Re: Dearmond 1800 wah/vol tb mod help
^ Yours has definitely been re-wired at some point, Spook. Here's a shot of the guts of my 1800, with the colours as indicated by Brook's image above. Also, as Brook mentioned, completely different PCB!
- Spook
- Spook
Woah, weird... If it has, its a very tidy job.
Just my luck...
- Spook
Looking online i found more with "my" colours, so maybe different versions.
- Spook
Does yours have a date stamp ?
mine says jan 14 1977.
There's a faint date stamp on mine (just above the switch) but I can't make it out. Guessing mine might be an earlier version. It has the same El Rad inductor as a Boomer, very similar board.
- Spook
looks like mine is a transitional one, with elements of the weeper.
- Spook
Bumping this bad boy, i really want to use this with the band...without using a loop pedal
So i need to figure out the wire colors...
- Spook
....also on my new switch, there are 3 rows of lugs, on the drawing just 2, do i pick 2 rows on the switch an just leave the other one alone ? does it matter witch rows i use on the new switch ?
- Spook
